Solved Renewal Pricing
Discussion in '3CX Phone System - General' started by 12494, Mar 21, 2017.
    12494 Member
    Apr 16, 2010
    280
    20
    We invoice customers for 3CX Maintenance Renewals in advance of their expiration.
    We first (in the past) went to the 3CX partner portal, looked up the correct license key and then went to BUY and entered the customer license to get the version and correct list price.
    We had all the information we needed in one site to find the correct renewal price.
    It appears that we no longer have the option in the portal to look up a renewal price for a specific license key. The BUY page only has a choice to purchase a new license.
    Was this someone's idea of making things better for us or an unintended consequence?
    Can you fix this please.
    Thanks.
    Regards,
    Allen
  2. Bianca
    3CX Support
    Dec 9, 2015
    49
    10
  3. 12494
    12494 Member
    Apr 16, 2010
    280
    20
    Hi Bianca,
    That is where I used to go and also where I went now.
    As I said in my previous message, there is only one choice on the drop down
    > I WOULD LIKE TO Purchase a New License.
    The STEP 1 CHOOSE A PRODUCT there are 3 choices - and they are all SPLA pricing.
    It sounds like I am not seeing the options that you say I should see.
    Allen
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    2,947
    178
    Screen Shot 2017-03-22 at 11.24.58 AM.png Allen - When clicking the first link - I was asked what I wanted to do: Upgrade License or Renew Maintenance.
  5. 12494
    12494 Member
    Apr 16, 2010
    280
    20
    Hi Craig,
    Well it appears differently for me - I only get 1 option and that is Purchase New.
    Allen
  6. 12494
    12494 Member
    Apr 16, 2010
    280
    20
    I only have an option to Purchase a New License.
    Could this be something wrong with my profile on your system (security privelege)???
    Allen
  7. craigreilly
    Feb 1, 2012
    2,947
    178
    I do not have any account to login to as I am not a reseller----
    Is there an option to logout - then try the link above again?
    Or perhaps a cache issue?
  8. 12494
    12494 Member
    Apr 16, 2010
    280
    20
    I called Rod this morning and he fixed my access in about a minute.
    Regards,
    Allen
