Renewing Certificate Doesn't Work
Discussion in '3CX Phone System - General' started by patricksmalley, Oct 8, 2017.
  1. patricksmalley
    May 13, 2016
    12
    I am trying to follow this KB article:
    https://www.3cx.com/docs/renewing-ssl-certificate/
    I replaced the files, then restarted the service, the old certificate is still being displayed when browsing to the website.
    I have checked the Nginx logs and there are no errors, no acknowledgment of a problem.
    Anyone have an idea of something to try?
  2. AJ Smith
    Aug 4, 2017
    21
    Also having issues...hopefully someone at 3cx will chime in soon!
  3. Sopock
    Sopock Member
    Jul 11, 2012
    448
    20
    Maybe you should try different browser and/or Clear SSL State in Internet Options...
  4. patricksmalley
    May 13, 2016
    12
    I have tried different browsers (Chrome, Firefox, Internet Explorer) as well as different computers, still the same old certificate.
  5. GiannosC_3CX
    GiannosC_3CX Guest
    Hi all,
    What version of the 3CX Phone system are you on (service pack, Linux or windows)?
  6. patricksmalley
    May 13, 2016
    12
    I am running: v15.5.3849.1
    Enviroment: Windows Server 2016 Standard v1607.14393.1715
  7. AJ Smith
    Aug 4, 2017
    21
    Any tricks to try?
  8. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,253
    63
    By the time nginx starts, it is not a cert+key file issue most likely. I have seen this a few others times when FQDN mapping to IPs gets mixed up, so some users get confused and are changing the certificates on the wrong machine by accident because the FQDN mapping is wrong.
    See if this is the case as I have seen this more times that I would have expected.
    Anyhow, if this does not work out you could try re-installing 3CX with a backup w/o Licensing Key and FQDN information option and re-upload the key+cert files during the installation process, ot be sure that it is done correctly.
    There is always the alternative to switch to using a 3CX managed Cert which will do all this for you automatically.
