Renumber Extensions 3-digit to 4-digit V14
Discussion in '3CX Phone System - General' started by mikegillespie, Jan 20, 2017.
  1. mikegillespie
    Feb 15, 2012
    19
    Is there a way to renumber all extensions from 3-digit to 4-digit with out completely reprogramming 3CX.
    For example: the client has 130 extensions within the range 200-399. we would like to renumber to 1200-1399.
    Mike
  2. MRM
    MRM
    Dec 21, 2016
    53
    Hi Mike G,
    Unfortunately this can not be done. Changing digits requires a complete configuration from the beginning.
    Regards,
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    Not even if extensions are edited in csv?
    EDIT:
  4. MRM
    MRM
    Dec 21, 2016
    53
    If you think of it logically there will be associated settings with your original number scheme, you'll probably end up with a corrupt database and figuring out where the issue could be & would be anybody's guess.
  5. mikegillespie
    Feb 15, 2012
    19
    Thanks all. Wow! That's quite a reasonable limitation of 3CX. The IPPBX's I have worked with from Avaya can do this very easily. I was not expecting that it was not possible.
