Repeat Dialing
Discussion in '3CX Phone System - General' started by thereverend, Feb 20, 2015.
  1. thereverend
    thereverend New Member
    May 29, 2011
    100
    Does 3cx have the ability to do Repeat Dialing and ring back the extension that started it for busy calls?
    11,277
    360
    I'm not certain how old this is http://www.3cx.com/ideas/index.php?page=idea_detail.php&i=139
    But it says it's being worked on. I'm assuming that the feature would be for extension to extension calls only, not outside calls.
    It's not "repeat dialling" as the PBX knows the status of the extension that was originally called.
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    This is camp on feature , strange that 3cx not implement this important feature ?
    Actually on v12.5 is implemened call back on transfert ....
    Important feature is receive callback request via ddi trunk ... for example external caller make incoming
    Call to xxxxxxxx2000 where 2000 is 3cx extension , than 3cx can play user is busy digit 5 for automatic
    Callback , than if calling id is correctly displayed when 2000 goes idle it recall external caller
