Repeat prompt
Discussion in '3CX Phone System - General' started by frenchy, Aug 13, 2008.
  1. frenchy
    Aug 27, 2007
    23
    Hi !
    In version 3 there was an option in the Digital Receptionist menu for the time out : we could Repeat prompt after a time out.
    In version there is not this choice ... How can I do the same ?
    Regards,
    Francois
  2. ess
    ess New Member
    Jun 8, 2007
    133
    I don't see it either. You could create an identical Digital Receptionist and have it forward to that one. Good Luck!
  3. frenchy
    Aug 27, 2007
    23
    Yes but it isn't a very "clean" solution. Why did the option disappear ?
  4. ess
    ess New Member
    Jun 8, 2007
    133
    I agree. Although, it is one of the more "clean" workarounds required for some 3cx setups. I am not sure what it disappeared. If you add it as a feature request, I'll be sure to vote for it.
