Replacing +44 with 0
Discussion in '3CX Phone System - General' started by streaters, Mar 22, 2018.
  1. streaters
    Mar 22, 2018
    We are UK based and trialling 3CX as an alternative to our normal pbxs.
    Our SIP provider presents the incoming calls in the format +441234567890. I want to replace this with 01234567890. I have put this on the Incoming CID rewrite options on the trunk
    Source +44(XXXXXXXXX)(.*) Replace 0(XXXXXXXXX)(.*)
    This does not work. So I suspect my formatting is wrong but I'm not sure how.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,255
    203
  3. streaters
    Mar 22, 2018
    Hi Thanks yes this sort of worked but turns out it's not quite what I am trying to achieve in the end.
    When a call comes in it now show +441234567890:support (Support is the name of the call answer group it rings and then on the line below 01234567890.
    Ultimately I just want 01234567890 to appear. Any thoughts
  4. Saqqara
    Mar 12, 2014
    1,255
    203
    Under additional notes - https://www.3cx.com/docs/cid-reformatting/
    These rules will not rewrite the incoming From:Display value,which means that if the call has been received with +18135910130, the display will still show these numbers, but the “core part” of the number to be dialed has been updated.
