Reporting - Graph Queue of Calls
Discussion in '3CX Phone System - General' started by markscottuk1979, Mar 29, 2017.
  1. markscottuk1979
    Jul 21, 2016
    Having found the monthly day-by-day report, I wanted to set it up to be emailed to management monthly (so at the start of the month the previous months call reports are emailed). It appears that this basic functionality is lacking..... I can email weekly but what is the point of sending an "unfinished" report every week.
    My manager has also requested that reporting is more interactive, so you click on a bar in the bar chart and it will break out the calls from that bar into a table.
    I think I might be missing an update or there is a bug as this is core functionality that every PBX has.
