Reporting Issue - Dates in US Format
Discussion in 'Windows' started by Michael Sleeth, Jan 18, 2016.
  1. Michael Sleeth
    Jan 17, 2016
    Hi.
    My knowledge of 3cx is not extensive so please go easy if I do not provide appropriate information or this has been explained elsewhere in this forum.
    I recently purchased a new hosting machine and installed v14 of 3cx on it. Now whenever I run any reports the dates are spitting out in the US format being mm/dd/yyyy. I really need these to generate in dd/mm/yyyy format.
    I have the appropriate time and date formats setup on the hosting machine but the dates still generate incorrectly.
    Any help I could get on this issue would be greatly appreciated.
    Cheers, Mick.
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,380
    84
    Hi Mick, at the moment the date format is not configurable, it is hard coded to this format.
  3. Michael Sleeth
    Jan 17, 2016
    Thanks for your response Nick.
    That is very strange that the format can not be changed.
    Cheers.
  4. David Mercer
    Feb 2, 2017
    Has this limitation been corrected either in V14 or 15?
    I can't understand the necessity for such a limitation, it makes reading the reports extremely awkward for some periods/months.
