Reporting VOIP/PBX hacking attempts
Discussion in '3CX Phone System - General' started by gschwab, Jul 15, 2014.
  1. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    Just curious, does anyone else take the time to report abusing IP addresses or is it just a waste of time?
    11,282
    360
    I did report a few, a long time back, when they originated from countries that you'd think might actually do something about it. I don't recall getting any sort of acknowledged so I pretty much gave up on that and now just blacklist IP's or IP ranges.
