Reports to show number of 3CX lines being used
Discussion in '3CX Phone System - General' started by pwashburn, Mar 30, 2015.
  1. pwashburn
    Apr 28, 2012
    We're running a 16 line version of 3CX Version 11. Trying to see a report to show me the number of simultaneous lines over time that are being used by 3CX so I can tell whether going up on the number of lines allowed is warranted. Is there such a report?
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    No there isn't but you can enable admin notification to get alerted when license or trunk limit is reached from Settings / General / Emai Notifications.
    Please post the report request on 3CX Ideas : http://www.3cx.com/ideas
