Reprovisioning Snom M700 not working
Discussion in '3CX Phone System - General' started by Serkan Bulut, Jan 23, 2017.
  1. Serkan Bulut
    Jan 23, 2017
    Hi There
    The reprovioning of Snom M700 doesnt work out of 3CX Console anymore. 3CX Support couldn't solve this problem. After adding the new extensions on 3cx Console the M700 must be rebooted to take over the new extensions to its database. This is annoying for the customers since he has to login to M700 for restart!
    Please fix this asap.
    Thanks and Regards
    Serkan
