Reprovisioning Yealink T26P
Discussion in '3CX Phone System - General' started by karingal, Dec 5, 2011.
  1. karingal
    Oct 19, 2011
    11
    Is there a trick to reprovision a phone? I have tried several times and the changes never take effect. In particular I am trying to change DSS key settings.
    Cheers
    Mark
  2. karingal
    Oct 19, 2011
    11
    Found the solution myself, but just incase others are interested.
    You click reprovision in the 3CX management console, then open the phone web interface, select Upgrade, Advanced and click on the Auto-provision button.
    Info found here: http://apetec.com/voip/3CX-YlnkProvision.htm
    Cheers Mark
