Request for a NAT option in the Dashboard
Discussion in 'Ideas' started by Khadija Imad, Mar 26, 2018.
Request for a NAT option in the Dashboard 5 5 1votes
5/5, 1 vote
Tags:
  1. Khadija Imad
    May 8, 2017
    8
    I am wondering if we can have a NAT option in the Dashboard to manage NAT. Specially when 3CX PBX detect that the contact information (IP address and port) received from a remote device, was not a Public IP because of a SIP Translation issue or any other NAT problem on the remote side, if this NAT option is enabled the PBX will use the source contact information instead (Public IP and port) received in the first Invite to properly send the packets to destination.
    Can we have any feature available to answer our needs ?
    Kindly,
  2. Platonik
    Dec 29, 2016
    9
    I agree this would be a useful feature that would allow to quickly set NAT settings whenever we're facing a NAT issue. This option would be right under the firewall check button and would allow setting Keep-alive or whatnot.
