Require external forwarding numbers to press a confirmation key before transferring inbound calls to
Discussion in 'Ideas' started by humansys, Dec 24, 2015.
  1. humansys
    Oct 28, 2015
    20
    When you configure an inbound call to ring an external number, if it's a cell phone and turned off or out of service area, it will pickup the voicemail immediately, routing the inbound call to the external number's voicemail instead of the 3CX voicemail. For areas with poor cell reception (where 3CXPhone is useless), this is a critical feature to make sure that inbound calls stay within 3CX, and allows you to have inbound ring groups and queues call cell phones and not worry about the phone system dumping callers into the cell phone voicemail on accident.
  2. humansys
    Oct 28, 2015
    20
    bump. most cloud phone systems support the 'press 1 to accept call' cell-phone forwarding feature.
