Reseller Tool?
Discussion in '3CX Phone System - General' started by EnrichGlobal, Jun 21, 2010.
  1. EnrichGlobal
    Jun 21, 2010
    Do people use 3CX to host multiple companies?
    For example can we use this software as a reseller tool? Get various companies signed up to us using 2talks services?
    Is it possible to have different billing rates per client?
    Thanks!
  2. zman574
    Jun 24, 2010
    57
    I am not 100% sure about the reseller availibity of the system, however I can tell you that the company I work for owns 7 total companies and I have installed it in all 7 under one license and reported this was my intetnion up front and they did not have an issue with it at all. So to make a short story short, I don't see any reason you couldn't. But be aware if you have not installed hardphones in remote locations before it can be tricky and it may require some pretty tricky network modificaitons. Also remember that you will only have one set of extensions so if someone at one company dialed another companies extension than they would ring through as a normal inside call.
