reset to default ports
Discussion in '3CX Phone System - General' started by next2, Sep 14, 2017.
  1. next2
    Apr 19, 2009
    39
    Once 3cx has been installed, is there any way to change the http and https ports used by the management console ?
    The network settings page allows us to change the SIP and Tunnel ports only.
    Thank you,
    Thomas
  2. IoannisM_3CX
    IoannisM_3CX Support Team
    Aug 10, 2017
    229
    18
    Hello @next2,
    Unfortunately this is not possible as those are hard-coded settings during the installation. What you can do, is to reinstall the system and set the wanted ports when prompted.
    Thank you
