Resolution for "3CX Phone for Windows"
Discussion in 'Ideas' started by Shayoo, May 11, 2017.
Resolution for "3CX Phone for Windows" 4 5 1votes
4/5, 1 vote
  1. Shayoo
    May 11, 2017
    It would be great if we can change the "resolution size" of the application.
    It look very small on wide screen with high resolution and you need to be a sniper to naviguate and use BLF.
    Of course you can change global display for all apps in Windows settings, but that's generally not fit for all
    Bye :)
    Nick Galea likes this.
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,970
    272
    Or use the new web client and windows client only for calling / as a softphone :)
  3. benratty
    May 23, 2011
    74
    Is there any chance the webclient will replace the desktop client as a softphone?
