[Resolved] Phones status on busy after 1 call
Discussion in '3CX Phone System - General' started by Matounetti, Jan 7, 2010.
  1. Matounetti
    Aug 27, 2009
    We've got a problem with the phones' status when we take one call : the others lines don't ring.
    All the extensions have been configured to use the phone 's status and not the pbx's one.
    I've got to reboot the server to retrieve a functionnal system :
    . BLF
    . others lines ringing
    During a small period it works but stop working after a period.
    Have someone already encountered a similar problem ?
    Informations :
    . 3CX + Cassini on Windows XP Pro SP2
    . 3CX v8.0.10116.583
    . Phones : ST2030 configured with 5 lines, C450IP, XLite Softphones
    . Phones and 3CX are on the same LAN
  2. Matounetti
    Aug 27, 2009
    Re: Phones status on busy after 1 call
    Resolved after editing the ALLOWUSEBUSYOPTFORGROUP custom parameters with a "1" value.
    The problem was that by default, 3CX only use the phone's status when the incoming call doesn't make a group ringing.
