Resolved: Pressing 0 during voicemail greeting
Discussion in '3CX Phone System - General' started by dcline97, Dec 1, 2010.
  1. dcline97
    Jan 21, 2010
    20
    Version 9, SP3.
    A caller (regardless if internal or external) connects to an extension, the call is not answered and the voicemail prompt begins playing. The caller then presses any key (usually 0) and they automatically get forwarded to extension 100. Where do I change where pressing a key during the playing of voicemail prompts forwards the calls to? I want them to go back to our digital receptionist at extension 802.
    Thanks,
    Dave
  2. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Re: Pressing 0 during voicemail greeting
    Have a look at re-configuring the 'Operator extension' setting under Settings -> General in the Management Console.
  3. dcline97
    Jan 21, 2010
    20
    We have already set that to extension 200, but it does not seem to make any difference - opting out of voicemail always sends you to extension 100. Is this a bug?
    Any other thoughts?
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,455
    92
    Definitely not a bug.
    Check again in Settings > General > Operator Extension
    Make sure it's changed to 200.
    Also check whether you accidentally changed the Voice Mail number to 200 instead by mistake.
  5. dcline97
    Jan 21, 2010
    20
    Nope - the operator extension is 200 and the voicemail extension is 999.
    I'm wondering if it is preprogrammed to always go to the first extension (which is 100 for us) when you press any numeric key during the playing of a voicemail greeting?
  6. LeonidasG
    Nov 19, 2008
    1,455
    92
    Hi try going to C:\ProgramData\3CX\Data\Http\Interface\ivr\root.ivr and open that file with a text editor.
    There should be a line saying the following:
    "rtOperator" expr="'100'" or "rtOperator" expr="'200'" where 100 or 200 is the number of your operator extension.
    Make sure this value reflects the one specified in your management console.
  7. dcline97
    Jan 21, 2010
    20
    It took some searching, but I found it! Here is where/what the file looks like in ver 9.
    C:\Documents and Settings\All Users\Application Data\3CX\Data\Http\Interface\ivr\root.vxml
    Sure enough, it was set to extension 100. I changed it to what we really wanted and the problem is now solved.
    Thank you so much!
    Dave
