RESOLVED: VCEHost.exe consuming 100% CPU
Discussion in '3CX Phone System - General' started by snowsam, Jul 26, 2011.
  1. snowsam
    May 26, 2011
    79
    I upgraded from SP1 to SP2 last evening and am now having issues of VCEHost.exe consuming 100% cpu on my well-endowed virtual machine running Server 2008 Web Edition 64bit.
    I'm not sure how to trouble shoot. I've restarted the processes the it climbs right back to 100% very quickly. Calls are having trouble being completed due to processes not running quickly.
    Anyone have any trouble shooting tips? I did a backup right before doing the upgrade, so I guess I could try to roll back to SP1.
    Eeek.
  2. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Is it resolved, like the post title says? If so, how?
    Thanks, Les.
  3. snowsam
    May 26, 2011
    79
    It was a dumb error on my part. Early on in the phone system set up I had turned on verbose logging to trouble shoot an issue. The logs had filled up the hard drive.
    I normally have some extra software (Event Sentry light) on the server to give me a heads up of warning when something like that is happening, but since this is on a new server I had not installed them yet.
    Looks like I should do that now!
    Thanks to one of the developers who took a quick look right at the time that I realized the hard disk was full.
    Sorry for the false alarm. If you see a similar 100% cpu problem, disk space is something to check!
    -Sam
  4. cfive
    cfive Member
    Aug 20, 2009
    284
    6
    Thank you Sam :D
    - Les.
  5. cnccomtech
    Mar 20, 2008
    I had error with VCEHost.exe to but it caused the computer not to be able to get online. We had to restart the computer to get the phone system to work again. I have more then 200 gig free.
    Thanks much
