Responding to a reply
Discussion in '3CX Phone System - General' started by jfields, May 16, 2011.
  1. jfields
    May 13, 2011
    I login and try to respond to a reply and it tells me to login again. Any ideas...
  2. willow
    willow Member
    Mar 1, 2011
    471
    Just fresh your webpage and it should go to the reply page.
