ResponseOrdering
Discussion in '3CX Phone System - General' started by CjGuSSa, Jan 28, 2016.
  1. CjGuSSa
    Feb 9, 2010
    We are using 3CX Phone system version 14 with latest service packs and licence for Callqueue. I want to change promptsets "<response name="QUEINTRO" order="YOUR_AT_POSITION+$Num$+QUEUE_TOBE_CONNECTED" />" located is xml file ResponseOrdering.xml
    I need the system said the number is not NUM_X, and said NUM_X_B. How can I do it?
  2. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,255
    63
    Could you give an example of how it works for you now and how you would want the prompt to be played instead?
  3. Mahir ÇATAL
    Jan 8, 2017
    Same problem for me.
    For example in turkey we have use num_1_0 for first queue but your system use num1 for first queue. it doesn't useful for our country. So we have to use NUM_1_0, NUM_2_O ..... for queue calls.
    your xml
    how can we change it, for our country.
