REST/Webservice interface to phone book
Discussion in '3CX Phone System - General' started by ubsysteme.de, Jun 9, 2017.
  1. ubsysteme.de
    Jan 4, 2011
    9
    is there a REST/SOAP interface for the 3cx public phone book?
    I would like to add phone book entries from our software. I know the 3cx Call Control API. But our software is not written in C#. So I need an other interface. (COM, REST, SOAP)
    Any suggestions
    Regards
    Mathias Pannier
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    2,007
    313
    Hi Mathias - Our software is able to query other databases via REST. If your software has a REST API then you can get 3CX to query your software for the number. That is how it has been designed to work...
  3. ubsysteme.de
    Jan 4, 2011
    9
    Hi Nick. Thanks for the feedback. Where can I find the documentation about this REST interface? Is it possible with the Standard version?
  4. Nick Galea
    Jun 6, 2006
    2,007
    313
    Hi - well currently you have to write a CRM plugin, but soon there will be an easier server based way for our web client.
  5. ubsysteme.de
    Jan 4, 2011
    9
    Why I have to write a CRM plugin? You have written that 3cx is able to query other databases via REST. I have thought "out of the box"?
