Restart 3CX server without restarting the PC?
Discussion in '3CX Phone System - General' started by mutti_wilson, May 5, 2008.
  1. mutti_wilson
    May 2, 2008
    53
    Does restarting all the services that are running restart the 3CX server or does the PC need to be restarted? Are there any other methods?
  2. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
    Here's a batch file that I use to restart all of the 3CX Services I use on the server when I need to. I don't use the Fax service, that's why there's a "#" in front of it, if you need to use it, remove the "#".
    Code:
    NET STOP "3CX PhoneSystem"
    NET STOP "3CX PhoneSystem Database Server"
    NET STOP "3CX PhoneSystem Digital Receptionist"
    #NET STOP "3CX PhoneSystem FAX Server"
    NET STOP "3CX PhoneSystem Media Server"
    NET STOP "3CX PhoneSystem Voicemail Manager"
    NET STOP "3CX PhoneSystem Web Server"
    NET STOP "3CX SIP/RTP Tunneling Proxy"
    ping 127.0.0.1
    ping 127.0.0.1
    NET START "3CX PhoneSystem Database Server"
    NET START "3CX PhoneSystem"
    NET START "3CX PhoneSystem Digital Receptionist"
    #NET START "3CX PhoneSystem FAX Server"
    NET START "3CX PhoneSystem Media Server"
    NET START "3CX PhoneSystem Voicemail Manager"
    NET START "3CX PhoneSystem Web Server"
    NET START "3CX SIP/RTP Tunneling Proxy"
    exit
    Hope that helps.
  3. mutti_wilson
    May 2, 2008
    53
    Right on. I was thinking about making a .bat file. You've already done the work. Thanks.
  4. jazzyjeff
    Dec 18, 2008
    Thank you I was so sick of restarting the pc to restart the server If any one doesn't know how to make a batch file here is a link to a site with help on batch files. http://www.computerhope.com/batch.htm But all you do is open notepade paste the above code and save as whatever.bat and double click it to run it.
    Cheers
  5. ess
    ess New Member
    Jun 8, 2007
    133
    Thanks guys, very helpful in testing environments. A lot less clicks :)
    Happy Holidays
  6. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    HI
    Version 7 has a 'Service Status' node. in there you have a 'Restart' and 'Restart All' option.
  7. davidarvixe
    Mar 30, 2015
    Hi!
    BUMP!
    I'm a complete noobie having issues with my 3CXPhones 12 for Windows. I'm currently getting the error whenever I turn on my PC and start the program,
    "3CX Phone for Windows could not establish a connection to the 3CX Phone System Web API. As a result, features like Contacts and presence information will not be available. You can still make and receive Phone Calls via SIP whilst we try and re-establish full functionality in the background."
    However, when I restart my PC and open the software again the program works but I have to restart my PC everyday in order to use the program.
    I've tried creating that BAT file but doesn't work. Maybe because of the version?
    Thanks!
  8. leejor
    11,262
    355
    First of all you've resurrected posts from about seven years ago dealing with a much different version of the PBX, and probably a different issue from your own. You really should have begun a new post.
    Are you saying that you have to restart the PC running the 3CX Windows phone, or the server running the 3CX PBX? If it is the PBX, as the original posts were referring to, do all phones have a problem , or just yours?
