restart the service
Discussion in '3CX Phone System - General' started by mademirci, Jul 3, 2008.
  1. mademirci
    Jul 1, 2008
    I need to restart the 3CX Server, but i do not want to go the Services and restart all 3CX services one by one, maybe a button on the web page just click Restart and the system automaticly restarts all the services...
    How can i do this with one button tpouch?
  2. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Here is a txt file you can rename as a .bat to stop and start all services in the correct order. Alternatively you can copy the text and paste it into a DOS box.
  3. francesco
    francesco New Member
    Jun 23, 2008
    102
    tank's for the script
  4. Nebula
    Nebula New Member
    Apr 6, 2008
    116
    Forgot to check which version of 3Cx you are using. The script works for V6 . If you are using version 5 the name of the tunnelling proxy service is slightly different. Also there are more services running on the licensed version than in this script.
