Restarting the system
Discussion in '3CX Phone System - General' started by druid, Mar 24, 2008.
  1. druid
    Mar 24, 2008
    Dear All, can any 1 tell me how to restart the 3cx phone system ?? i didnt find it in the manual, i have just taken the free version but i am not able to set it up successfully, i have used 2 sip phones, 1 3cx voip client and other is sjphone, i entered the correct credentials but my phone is not resgistering !! i am doing it on my lan but no success so far, any1 with a good idea as how to solve this issue, the error i get is registration failed, credentials dont match. !!
    Thanks in advance
  2. josvic
    Apr 24, 2007
    51
    At the moment the only thing to do this to STOP the 3CX Services direct from your Windows Control Panel.
    It be very nice if this where an option in the next release..., include it in the wishlist.
  3. Halea
    Halea New Member
    Jan 5, 2008
    151
    Depending on what you're trying to achieve you may need to restart the "3CXPhoneSystem" service alone or all eight 3CX services. It's a bit of a pain, especially that the fax service most often sticks and doesn't properly shut itself down, in which case you might have to restart windows all together.
    To make things a bit easier you might want to create a batch file to stop all 3CX services running. The fax service's eccenticities make me stay away from that approach, but if you simply want to restart the main service, it should be ok.
    Halea
  4. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    If there are any active calls at the time when you are restarting phone system service it is highly recommended to restart media server service as well.
    Regards
  5. h2009
    h2009 Member
    Mar 15, 2008
    447
    How can you create a batch all stop (restart) file? I'd be interested in making that.
  6. SY
    3CX Support
    Jan 26, 2007
    1,825
    net start ...
    net stop ...
    net /?
    NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
    HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
    SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
  7. h2009
    h2009 Member
    Mar 15, 2008
    447
    so in start/run > net stop 3cxphonedatabase ?
  8. SY
    3CX Support
    Jan 26, 2007
    1,825
    Hint:
    if you need to stop it then
    net stop "3CX PhoneSystem Database Server"
  9. h2009
    h2009 Member
    Mar 15, 2008
    447
    ah brilliant thank you very much!
  10. bluefox8080
    bluefox8080 New Member
    Oct 28, 2007
    181
    To save you some typing:
    Copy and paste this in to a text file and save it as restart3cx.cmd (or anything else), then run it
    Hash out (#) the things that you do not what to restart
  11. Halea
    Halea New Member
    Jan 5, 2008
    151
    NET START /? and NET STOP /? give you a bit more info about how to do it.
    The service name needs to be entered exactly as it shows under the "services" table in windows, and needs to be between double quotes if it contains any space characters.
    Halea
  12. h2009
    h2009 Member
    Mar 15, 2008
    447
    Ah thanks for that little bit of code. I'll give it ago and let you know how i got along.
  13. josvic
    Apr 24, 2007
    51
    Good batch Bluefox8080...
  14. demonofsteel
    demonofsteel New Member
    Mar 28, 2008
    105
    I wonder if I'm the only one, but everytime I try to stop the fax service, it fails... The fax service did not even uninstall when I uninstalled 3CX Phone Server to put in on another server.
  15. josvic
    Apr 24, 2007
    51
    No, you are not the only that this happens... me too, but If I restart the system past a period of time works again to restart the fax service.
  16. demonofsteel
    Mar 28, 2008
    105
    Yes, that works, but it's not a very good solution I think. I can hardly think of a moment where nobody in an office is using his phone. That means the system would need to be restarted after work hours, but what happens if fax needs to be used during the day?
    Well, I don't use the fax service, so it does not matter to me, but it could be a lot of problems for those who use it.
  17. josvic
    Apr 24, 2007
    51
    It's a very good idea to implement in the 3CX web interface a buttom to START/STOP 3CX Services...
  18. demonofsteel
    Mar 28, 2008
    105
    that's true, a start/stop/restart option would be much better than having a batch file handling all of the services.
  19. h2009
    h2009 Member
    Mar 15, 2008
    447
    if anyone wants the batch file i can post it for them.
    Fully working (slight edit from the above code, so the window closes after)
  20. hoadzman
    Nov 26, 2008
    Well I've been trying to get some help just to install the trial software to see if its worth my time, and i cant get no help, i'm already frustrated can some one help me get it installed atleast, the services fails to start when installing; "3CX SIP/RTP Tunneling Service Stopped" windows closed service
