Restore Fails on 5.1
Discussion in '3CX Phone System - General' started by future-data.biz, Feb 21, 2008.
  1. future-data.biz
    Oct 15, 2007
    26
    Dear All,
    I followed the backup and upgrade procedure as per 5.1 on the forum.
    Once the upgrade was done I proceeded to restore the database. It is hanging on history table and its taking a long time to pass this stage.
    Anyone got any ideas.
    Kind regards,
    Rob
  2. Pentangle
    Pentangle Member
    Dec 6, 2007
    261
    Yes, leave it, it's not hung, it just takes AGES to process.
  3. amartini
    Dec 28, 2007
    17
    the script has a 7200 seconds of timeout. In my PBX (pentium 4 2ghz, 1 Gbyte ram), I cannot import the history because the script end after 7200 seconds.
    Can I copy the history in other way?
    Thank you
  4. ITWorks
    ITWorks New Member
    Apr 7, 2007
    121
    I have the same question so I am bumping this up again.
  5. future-data.biz
    Oct 15, 2007
    26
    Hi All,
    My restore worked in the end. It just took ages to restore.
    3CX support also noted this.
    Regards
    Rob
  6. amartini
    Dec 28, 2007
    17
    Yes,
    If I install the 3cx PBX in a dualcore 2ghz, 2gbyte ram, I can restore the history, but in my PBX PC (pentium IV) The script go in timeout.
    Marco
  7. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    Yes it has to do with history of the phonecalls. The next time you shouldn't backup the history of phonecalls, only the rest.
    You will see, it will run fast then.
