Restore Operator extension
Discussion in '3CX Phone System - General' started by Janek, Oct 15, 2009.
  1. Janek
    Oct 6, 2009
    11
    After installation I decided to change numbering plan & deleted the operator extension.
    Can I create new operator extension or give another ext the required properties
    I guess the main issue would be there's no default for incoming calls
    I'm on version 8 Beta
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,399
    79
    I dont know how you did it, there are some safeguards so that you cant delete the Operator extension.
    You can assign any extension as the Operator extension, there are no special properties for an Operator extension all you need to do is go to :
    Settings > General > Operator extension: XXX set whatever you want.
  3. Janek
    Oct 6, 2009
    11
    Thankyou
    resolved now
    I deleted the original default 100 ext & couldn't see what had replaced it
    I checked your suggested settings & can confirm operator ext is set
    I tested & I cannot delete that in my current 3CX v8
    ----just one of those things us newbies do, to give you oldies a chance to tut tut at us
    (You've no idea how much calling myself a newbie flatters me!)
