Restrict an extention from calling
Discussion in '3CX Phone System - General' started by William400, Aug 30, 2007.
  1. William400
    William400 Well-Known Member
    Aug 21, 2006
    1,005
    I have a set of extensions which are in satellite offices. They have a 3CX extension wthat works fine, however i would like to restrict them form making outbound calls via the 3CX lines.
    I cannot see to see this in the config.
    Can this be done?
    William
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    On the outbound rules you can choose what extensions can dial outbound or not.
    Cheers
  3. William400
    Aug 21, 2006
    1,005
    Yep, was blind to that one, was looking for an option like ' Extension can make outbound calls'
    Thanks for this.
