Restrict calls from one extension to another
Discussion in '3CX Phone System - General' started by you2web, Dec 27, 2010.
  1. you2web
    Sep 21, 2009
    15
    Hey
    I have one small question.
    i have extensions from 100-200
    Is it possible to make rule which will deny calls from extension 100 to letsay extension 105.
    Thank you for help
    Uros
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Extension configuration->Forwarding rules->Exceptions
  3. leejor
    10,368
    229
    Also....if you are using a VoIP set/ATA, that has dialplans within it, that will allow you to make dialing restrictions/allowances specific to that set.
