Restrict group from seeing some globally published groups
Discussion in 'Ideas' started by bbaker73, Jun 29, 2017.
Restrict group from seeing some globally published groups 5 5 2votes
5/5, 2 votes
  1. bbaker73
    bbaker73 New Member
    Nov 27, 2015
    143
    26
    Using groups to help organize company departments and make switchboard presence in 3cx client easier to navigate. Most groups have "Publish group information to all members", so other groups can see that group and extension presence. However I have some groups that I'd like to restrict seeing SOME of the other groups to limit calling directly when they should be calling a queue, and also to clean up the presence view to only what is necessary.
    Feature/right for the group would be "Can see IF published globally" and multiselect from a list of all other available groups, so your list would contain other groups that this group should see, if the other groups are publishing under their global rights setting.
