Restricting calls to paging/ring Groups
Discussion in 'Ideas' started by Tupi, Jan 4, 2018.
Restricting calls to paging/ring Groups 5 5 7votes
5/5, 7 votes
  1. Tupi
    Aug 31, 2017
    For a client I implemented a paging group for emergency cases which should call to every deskphone. It would be nice to restrict the ability to call the paging group to certain extensions. Background for this is that we dont want that >400 people could call the paging number back and speak freely to all the extensions in the building.
  2. Maaax
    Jul 30, 2018
    5
    I have exactly the same problem. A chance to set permissions to call group numbers would be very useful!
  3. Trent Hamilton
    Aug 10, 2017
    19
    Yes! 100x yes. Imagine a school situation where kids learn the paging number and find it funny to continually dial it...
  4. Brian Buell
    Aug 9, 2017
    36
    5
  5. Trent Hamilton
    Aug 10, 2017
    19
    Brian, that workaround assumes the paging device is set as a regular extension. If the paging is set up as a paging ring group then the forwarding rules are ignored.
  6. TimWinkle
    Oct 6, 2016
    6
  7. Bruno PELZER - CELEM
    Dec 11, 2017
    21
    +2... I had the same request from 2 of our customers !
  8. ronj
    Aug 2, 2016
    +3 A definite must add!
  9. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,545
    298
    Read on... they talk about putting a Multicast button on the phones that need paging ability.
    So, phone initiates multicast page directly to x.x.x.x:yyy and does not use the 3cx at all.
    Then all the phones have a multicast listener. And play audio when there is a page. Also, can setup multiples of these... for zones/buildings on a campus.
    I still think your idea is valid.
