Restrictions on simultaneous incoming/outgoing calls
Discussion in '3CX Phone System - General' started by complex1, Jan 17, 2016.
  1. complex1
    complex1 Active Member
    Jan 25, 2010
    752
    38
    A customer have a SIP Trunk with unlimited simultaneous incoming/outgoing calls.
    He has a 3CX 8SC license.
    He want to restrict incoming calls to a max. of 2 simultaneous calls, but no restrictions on outgoing calls.
    In "SIP Trunk Settings > Simultaneous Calls" you can manage the max. sim. calls, but this is for all calls for that Trunk, inbound and outbound together.
    He want to separate incoming and outgoing calls over the same Trunk.
    Is this possible in 3CX and can you point me into the right direction to accomplish this?
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Sorry this feature is not possible via a single sip trunk.You will need to split this into two trunks.
  3. complex1
    Jan 25, 2010
    752
    38
    Hi David,
    Thank you for your reply.
  4. bardissi
    bardissi Member
    Jan 31, 2012
    318
    Many providers allow you to have as many registrations as you want (assuming username / password registration vs ip authentication)
    Setup two username / password accounts to the same sip trunk provider account.
    Setup 2 separate voip provider account.
    Set the max limit of sim calls on the 1st voip provider account.
    Assign your did's against it.
    Then use the other for outbound calls.
