Retry failed fax emails
Discussion in '3CX Phone System - General' started by pscs, Jun 12, 2012.
  1. pscs
    Jan 19, 2012
    14
    Occasionally we have problems where the 3CX fax server can't contact the email server, eventually the faxes end up in the
    "C:\ProgramData\3CX\Data\Fax\Faxes\Failed"folder
    Is there any way of making it retry these failed faxes once we've sorted out the email server problems? eg can I move the XML & TIF files to the 'ToSend' folder? If so, do I need to edit the XML file?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Have you tried copying the files back into the folder to see if they get processed?
    Maybe after you move them, restart the 3cx Fax Server service.
    If this works, then try creating a batch file that runs periodically.
  3. pscs
    Jan 19, 2012
    14
    I've tried that - it doesn't work :(
