Returning missed calls from 3CXphone
Discussion in 'Windows' started by gmcfad, Feb 14, 2010.
  1. gmcfad
    Feb 14, 2010
    I'm new to 3cx so here goes. Installed 3CX last night and now have everything working correctly - inbound and outbound using Viatalk as my SIP provider. Configured 3 extensions, two using 3CXphone and one with Cisco 7912. As stated, inbound and outbound, as well as extension to extension work great. But, when I try to return a missed call using 3CXphone (using the missed call icon) I get the following error:
    11:49:36.281 [CM503020]: Normal call termination. Reason: Not found
    11:49:36.281 [CM503016]: Call(37): Attempt to reach <sip:1XXXXXXXXX@192.168.1.30:5060> failed. Reason: Not Found
    11:49:36.265 [CM503014]: Call(37): No known route to target: <sip:1XXXXXXXXXX@192.168.1.30:5060>
    11:49:36.265 [CM503010]: Making route(s) to <sip:1XXXXXXXXXX@192.168.1.30:5060>
    11:49:36.250 [CM505001]: Ext.100: Device info: Device Identified: [Man: 3CX Ltd.;Mod: 3CXVoipPhone;Rev: General] Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [3CXVoipPhone 4.0.9878.0] PBX contact: [sip:100@192.168.1.30:5060]
    11:49:36.234 [CM503001]: Call(37): Incoming call from Ext.100 to <sip:1XXXXXXXXXX@192.168.1.30:5060>
    It appears that I am missing a "9" so no outbound route is found. It works fine if I dial the number from the number pad - using a "9" in front of the missed number.
    What am I overlooking???
    Thanks much.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,479
    67
    My opinion is the issue you describe is a normal one for any phone: it receives the "pure" external phone number, so to dial it back the outbound rule prefix it is required.
    However, I guess such kind of issue may be avoided by tuning the format/kind of outbound rule(s) in the PBX - "call from extension(s)", "call to numbers with a length of" - to avoid an outbound rule prefix.
    Regards
    vali
  3. leejor
    10,757
    286
    Maybe we need an option on the next 3CX softphone where you can "predial" a prefix on the keypad, then hit the re-dial last number button?
  4. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    667
    7
    The better way is to modify Caller ID in the Inbound rule. See for example http://www.3cx.com/forums/modification-of-inbound-cid-12495.html
  5. Vali_3CX
    Dec 12, 2008
    1,479
    67
    We already implemented this feature in the Skype gateway, exactly because of this issue, but it's implemented at a, let's say, elevated level, it automatically appends a prefix tho the "from" calling the SIP destination, so this one, when call-back, has nothing to do but just to click the button. But this is a gateway, while a phone is an "end-point", a different story.
  6. pdq
    pdq
    Dec 3, 2009
    82
    Where is Global Options Node?
  7. Vali_3CX
    Dec 12, 2008
    1,479
    67
    What "global options node"? :roll:
  8. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    Your PBX > Settings > General > Global Options
