Revolabs FLX(2) support [DECT Conference phone support]
Discussion in 'Ideas' started by Brad Allison, Nov 29, 2017.
Revolabs FLX(2) support [DECT Conference phone support] 5 5 1votes
5/5, 1 vote
  1. Brad Allison
    Jun 7, 2017
    67
    20
    add support and provisioning files for Revolabs FLX and FLX2 conference phones.
  2. Brad Allison
    Jun 7, 2017
    67
    20
    All current 3CX supported conference phones are hardwired which is great if the customer has proper cabling to accommodate their conference table. More times than not the customer just connects a 15' or longer cable to their hardwired conference phone and drags it over to the table.
    This is very unprofessional and is a safety hazard.
    Support for DECT conference phones is something that should be addressed.
    Please add Revolabs FLX2 to supported list of conference phones for addressing DECT.
    The Revolabs FLX UC is also a nice hardwired unit as well for where hardwired makes sense.
    Revolabs sells both as operability verified with 3CX.
