REW/FFW while listening to a VM
Discussion in '3CX Phone System - General' started by brianoakes, Sep 26, 2012.
  1. brianoakes
    May 12, 2012
    95
    A question/request came from users. In our old phone switch, we used to be able to press the 7 or the 9 key while the message was playing. When you pressed 7 it would rewind 2 seconds, then 9 would fast forward 2 seconds. This was very helpful if someone missed a phone number or something. This way they wouldn't need to relisten to the whole voicemail.
    Is something like this possible?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    530
    12
    take a look on this topic
    http://www.3cx.com/forums/rewind-voicemail-31384.html
  3. brianoakes
    May 12, 2012
    95
    Thanks I missed the reply.
    Using Media player won't do on this one... pretty neat feature when ya think about it :)
