RFC 4967
Discussion in 'Windows' started by Montclairguy, Apr 20, 2010.
  1. Montclairguy
    Feb 23, 2010
    68
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Sorry, but your request is not completely clear in context of
    P.S. What is the reason to use http://www.packetizer.com if RFC is available on http://www.ietf.org ?..
