Ricoh multi-function Fax
Discussion in '3CX Phone System - General' started by davesampieri, Feb 22, 2011.
  1. davesampieri
    Jan 19, 2011
    5
    Hi, we are in the process of setting up a trial of the 3CX PBX and have a question regarding faxes.
    The Ricoh Aficio multi function units appear to support faxing via SIP, but I cannot find any in-depth information on using them with 3CX.
    Here is the scenario:
    Each Ricoh unit has a phone line and a network connection. The network connection has an IP address that is used for printing and scanning.
    I would like to setup the Ricoh to use the network to register with 3CX as a fax machine so that it can send and receive faxes via 3CX.
    I understand that not all SIP providers support T.38 and I am willing to purchase additional software if necessary, but I think the first hurdle is to figure out the SIP settings on the Ricoh units.
    Please let me know if you have any experience with setting those up and can offer some advice.
    Thanks - Dave
    10,360
    226
    You say that the unit "appears" to support SIP faxing. Is that not documented in the manual? Can Ricoh not provide support at all? Have you actually had the machine set up to fax, other than using the phone line connection, i.e. , directly with a VoIP provider?
    A number of multifunction units on the market make use of an Ethernet (or wireless) connection for scanning and Faxing, but do not use that connection for faxing, that's why they still come equipped with a phone line connection.. You have to confirm that the machine is a SIP device, and will register with a SIP provider.
    Even then, there is no guarantee it will pass faxes, without , perhaps, a lot of tweaking.
  3. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    We recommend using relayfax with 3cx for fax sending
    Contact me for details
