Right-click in windows client
Discussion in 'Ideas' started by optixuk, Sep 30, 2015.
  1. optixuk
    Oct 16, 2009
    23
    Why does a right-click in the client take you to the settings page?
    On almost any other Windows application you get a context menu and the option we'd really like to use is Paste so that you can take a phone number from the clipboard and dial it easily using the mouse. At present the only way to paste a number in is to revert to the keyboard and use Control-V
    Can we please have standard Windows behaviour as found in all the other VoIP clients we have used in the past?
