Ring a SIP phone and an ATA at the same time, any issues ?
Discussion in '3CX Phone System - General' started by Fatboy40, Sep 16, 2010.
  1. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    I'm setting up 3CX to replace our current phone system (a Samsung Compact DCS II, a digital phone system), and on our shop floor we have a single phone that has an analogue port presented on the rear of it that connects to a bell so that the ring of an incoming call can be heard over loud machinery.
    Now with a SIP phone I can't immediately replicate this setup ?. I'm not aware of any SIP phone that presents an analogue port on the rear (allmost an integrated ATA ?).
    So all I can think of is to install a SIP phone registered to the virtual extension, and then install an ATA which is also registered to the same extension and connected to the bell. Am I correct in thinking that with 3CX more than one device can be registered to a virtual extension so that in theory the above solution would work ?.
    Thanks.
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    Yes you can do that.
    Your other choice would be to set up a second extension with the ATA as that 2nd extension and then create a ring group with Ring All and add those two extensions.
  3. Fatboy40
    Fatboy40 New Member
    Aug 2, 2010
    170
    Thanks for the confirmation :)
