Ring additional extension when first extension dialed
Discussion in '3CX Phone System - General' started by fonewiz, Oct 22, 2015.
  1. fonewiz
    May 13, 2015
    44
    I have a request from a customer that would like her phone to ring when another particular extension rings.
    I realize I can setup ring groups but in this case, it won't work because sometimes people call the extension directly.
    Example of what the user is asking for:
    Internal or external caller dials Ext A directly --> Ext A rings & Ext B rings
    This is simple to do on other systems but I have never tried to do this with 3CX and I can't seem to find a way.
    I am aware of configuring two phones for a single extension but in this case, Ext B needs to remain a separate extension, just need to ring B whenever A is dialed.
    At the moment, the only thing I can think of is to tell the user of Ext A to start giving out a different extension to everyone that's actually a ring group extension. This however does not hold up for things like DialByName and probably a bunch of other things.
    Thanks in advance for any help from anyone that has solved this issue before.
  2. lneblett
    lneblett Well-Known Member
    Sep 7, 2010
    2,086
    64
    You have two options:
    1. If a multi-line capable phone, you can always manually set-up one of the unused line keys to be the same extension as the other extension. Fundamentally, this phone would then have 2 accounts and will ring whenever the primary or secondary extension is rung, be it as a direct call or as a ring group, etc.
    2. Assuming the other extension has BLF capability, set-up a key to monitor the desired extension. While it will not ring per se, there is at least the visual indicator that will indicate a ring.
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    458
    75
    I recommend the #1 option. A third option is to put Extension B's extension number in as the mobile phone for Extension A and set Extension A to "ring my mobile at the same time".
