Ring and hunt group
Discussion in '3CX Phone System - General' started by altexy, Nov 9, 2007.
  1. altexy
    Apr 3, 2007
    What is the difference?
  2. miraportuga
    miraportuga Member
    Aug 7, 2007
    297
    To tell you the truth i havent tried this myself but i believe it works like this. you have 3 extensions, 1000, 1001, 1002, if set to hunt group it will first ring on 1000 then after some time it will pass to 1001 then again it will pass to 1002...
    Anyways, if this is wrong feel free to correct me..
    Cheers :p
  3. Mori
    Mori New Member
    Mar 23, 2007
    223
    Please have a look in the manual, section 9.
    http://www.3cx.com/manual/3CXPhoneSystemManual31.pdf
  4. altexy
    Apr 3, 2007
