Solved Ring Group forward to external number
Discussion in '3CX Phone System - General' started by THCO, May 16, 2017.
  1. THCO
    May 16, 2017
    56
    11
    Hello all,
    First let me say that since I have been playing with 3cx is has been amazon. It is really stable and easy to deploy. I have 1 nagging problem. I am running version 15.5 beta on the free version.
    I setup a ring group with 2 extensions included in the ring group. I want to to forward to an external number after 15 seconds if no one answers. When I test this I get an error message in the logs that state
    05/16/2017 3:25:40 PM - [CM503003]: Call(C:16): Call to <sip:131@172.18.2.3:5060> has failed; Cause: 487 Request Cancelled/INVITE from 172.18.2.17:5060
    05/16/2017 3:25:40 PM - [CM503003]: Call(C:16): Call to <sip:132@172.18.2.3:5060> has failed; Cause: 487 Request Cancelled/INVITE from 172.18.2.22:5060
    05/16/2017 3:25:40 PM - [Flow] Target endpoint for XXXXXX can not be built!
    I have no clue where to go from here, Anybody can chime in and help would greatly be appreciated.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,514
    361
    Hello @THCO
    Do you have an inbound rule in place that matches the number you are trying to dial? Are you using the destination if no answer of the Ring Group?
  3. THCO
    May 16, 2017
    56
    11
    I have an inbound rule that was created when the ring group was created. When I call the DID assigned to the ring group everything works great, the 2 extensions ring. I have destination to no answer is selected to forward to outside number. This is the issue I am having. It will not forward and generates the two error messages I posted in the original post.
    I did check in the settings that in pbx settings, that Allow forwarding to external numbers in Ring Groups and Queues is checked.
    The strange thing is, I can forward to external number on an individual extension and that works great.
    Is almost that virtual ring group extension does not have permission to use any of the out bound rules I have created.
  4. datamerge
    datamerge New Member
    Nov 19, 2014
    176
    22
    In your outbound rule have you specified any "calls from extensions", or "calls from extension groups"? If you have that rule wont fire from a ring group overflow. You need to construct a rule only based on destination parameters. i.e. "Calls to numbers starting with prefix" and/or "Calls to Numbers with a length of"
  5. THCO
    May 16, 2017
    56
    11
    That worked awesome, it is now working correctly. I can't thank you enough for helping me with this.
  6. YiannisH_3CX
    May 10, 2016
    5,514
    361
    Sorry i did mean outbound rule not inbound, glad to hear all is working now
