Ring Group - Incoming Caller ID not visible
Discussion in 'Windows' started by mvla, Feb 9, 2016.
  1. mvla
    Nov 17, 2010
    I have a couple of ring groups with two or more phones in every group.
    One group has the problem that the telephones in this group don't see the incoming caller id, they only see the groupname?
    The other groups work fine but I can't find the difference in this group....
  2. richardwvm
    Dec 21, 2015
    27
    Hi MLVA,
    Assuming you're using V14, then you can tweak what is sent with the Caller ID in Troubleshooting -> Parameters.
    Search for CID and you'll get two options called APPENDCIDQUEUE and PREPENDNAMETOCID. I set both these to zero in order to receive just the phone number on our Snom phone's display; works a treat.
    HTH, Richard.
    Moawia Noor likes this.
  3. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,243
    61
    ...or instead of going into the Parameters and risking 'breaking' something by accident, you could go to Settings -> Company Phonebook and press the "Phonebook Options" button and use the GUI to do the same thing....
    (this is how to get to these options in V14 SP2)
  4. richardwvm
    Dec 21, 2015
    27
    Lol, hadn't even noticed that dialog; wood, trees!
  5. Moawia Noor
    Mar 12, 2017
    24
    This was so simple and very helpful , I just have to say thanks .
