Solved Ring Group Name Appearing on Phones
Discussion in '3CX Phone System - General' started by millennium2, Mar 15, 2018.
  1. millennium2
    Apr 8, 2011
    57
    We upgraded a tenant to 3CX v15...before the upgrade, when someone called a DID assigned to a Ring Group, the Ring Group Name would first appear on the phones, followed by the Incoming Callers DID.
    Ex: RingGroupName: 212-XXX-XXX
    Now, after upgrading to v15, it is reversed...that is the DID appears first followed by the RingGroupName.
    Ex: 212-XXX-XXX: RingGroupName
    Is there a way to reverse this back so the RingGroupName appears first? Any advice would be greatly appreciated. Thank you!
    Tenant is using Yealink T46g phones.
  2. Saqqara
    Saqqara Well-Known Member
    Mar 12, 2014
    1,249
    202
    Change the settings under Contacts - Options
    millennium2 likes this.
  3. millennium2
    Apr 8, 2011
    57
    Aha! Found it! Thank you!!!
