Ring Group, not "hunting".
Discussion in '3CX Phone System - General' started by shepp, Jul 11, 2011.
  1. shepp
    Jul 11, 2011
    Very simple system with 3 phones, all I'm trying to do is get all 3 to respond. Have set all extensions as ring group members, set ring strategy as ring all. Only the first one would ring incoming.
    Ideas?
    Side note, incoming calls get a busy signal first call, but can connect on second call.
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    #2 nbailey, Jul 11, 2011
  3. leejor
    11,086
    325
    Have a look at the 3CX server log during an incoming call.
  4. willow
    willow Member
    Mar 1, 2011
    471
    I suspect you have an issue with the phones not being registered or something like that.
  5. shepp
    Jul 11, 2011
    Sorry for not responding, I resolved the problem later that night.
    I unchecked, saved, rechecked, saved the "Connect to Queue/Ring Group" and it started working. Oddest thing.
