radelman said:Two ext set up, both internal, one to a GXP2010 and one extension to dial an outside number. With both exensions in a ring group, only the internal extension rings. Any thoughts?
darrellchapman said:radelman,
This sounds like a bug to me. If each extension is behaving as expected but not in the ring group, then I would expect there's a bug somewhere in the system.
You might want to repost this issue to the 3CX Phone System General forum instead on this one to see if someone their has a solution.
Darrell Chapman
darrellchapman said:Stepan,
First of all, I'm not sure who your replies where to (in either forum); me or the original poster? This is not my post. I was simply trying to help the poster.
My reply about the "posting guidelines" has to do with the fact that if there were some, radelman wouldn't have posted this to multiple forums.
Darrell Chapman
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
