ring group not working properly
Discussion in '3CX Phone System - General' started by radelman, Mar 5, 2008.
  1. radelman
    Feb 21, 2008
    60
    I can dial the ext that is forwarded to the outside line and that works fine. I can dial the ext of the GXP phone and that works fine. When I set up a ring group to ring both ext simultaneously, only the GXP phone rings, but the external number is not dialled.
  2. radelman
    Feb 21, 2008
    60
    Wow, now I'm replying to my own posts. The ring group set up to ring multiple extension will only RING an extension in a ring group even though that ext is programmed to dial an outside number. If anyone out there is an "expert" or "professional", perhaps they could report this bug to the powers to be. Does anyone else have this problem?
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Please check this post
    http://www.3cx.com/forums/ring-group-not-working-properly-4470.html#p20795
  4. radelman
    Feb 21, 2008
    60
    Matt,
    I set the ext for the outbound rule as you suggested, but the ext with the outside number does not forward when accessed by the ring group. The ext rings an outside line if the ext is dialled directly. When the ext is dialled directly, the ext does not show ringing on the line/ext status page, which is probably as it should be.
    I set the ring group as option "9" on the DR. I tried only having the ext with the forwarded number in the ring group, but when I choose "9" from the DR and look at the line/ext status, the ext is still showing as ringing.
    Any thoughts?
