Ring Group Office Hours
Discussion in '3CX Phone System - General' started by aberry, Nov 30, 2015.
  1. aberry
    aberry New Member
    Jan 13, 2015
    118
    7
    I have a couple DIDs routing to ring groups for reception desk type situations. Unfortunately it looks like these ring groups do not follow office hours. Is there any way to force the ring group to obey the global office hours, or even better the office hours of the extension members?
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,103
    204
    Would the Office Hours of the DID help you at all?
  3. aberry
    aberry New Member
    Jan 13, 2015
    118
    7
    Thanks for that, I didn't realize that you could set the office hours for the DIDs specifically. I think that is going to allow the behavior that I was looking for.
  4. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Hi Aberry
    Yes as craigreilly setup office hours on the DID and route the Calls to a different destination than the Ring group. The ring groups will ignore the forwarding rules for Extensions except in two specific scenarios:
    1) Away and forward call to mobile or External Number
    2) out of office and forward call to Mobile or external number.
    There is a reason for that as you can imagine what would happen if one of your ring group members was away>> Send call to voicemail, he would be getting all the Ring Group calls. What is the exact scenario that you are trying to do?
  5. aberry
    aberry New Member
    Jan 13, 2015
    118
    7
    Logically that makes sense, thanks.
    I think I have the behavior I was trying for, during business hours connect to ring group, outside connect to VM of extension. Basically [Call Received] > [Office Hours Check] > A. [Connect to Ring Group] B. [Connect to VM]
    I added office hours rules to the DIDs and that seems to have given me that behavior. Thanks again!
